How to remove CCM 4.0 from server
Sep 21st, 2010
i am using CCM 4.0 on the dell server now i want to uninstall the CCM from server any body know about it.???
Aaron Harrison Tue, 09/21/2010 - 03:10
CCM4 doesn't allow you to remove the application via add/remove programs; so if you don't want it to be a CCM server any more, just get the Dell Serverguide CD for the particular model of server you have, and rebuild it from scratch using normal OS media.
If this server has been running CCM it probably has lots of odd settings applied so you would be best advised to reprovision it with a fresh OS installation.
Please rate helpful posts...
