09-21-2010 12:56 AM - edited 03-06-2019 01:05 PM
Dear Experts,
I have Cisco 3750 (24) P switch, i need bandwidth resctrict 30 mb on interface fa1/0/1 , but it's exceeded more than 40 mb
interface fas1/0/1
no switachport
ip add 192.168.1.1 255.255.255.0
srr-queue bandwidth limit 70
but when i check after given this command bandwidh exceeded more than 30 or 40 mb it's not rescrict.
so what is the issue and how can i solve this.
Please help me
Solved! Go to Solution.
09-21-2010 01:43 AM
Then bandwidth limit command will limit the bandwidth of the interface specified as percentage along with the command. So in order to limit the bandwidth ot 30 Mb on a 100 Mb interface please use srr-queue bandwidth limit 30 under the interface. Also it seems you have already enabled mls qos globally ( this is needed).
Rgds,
Souvik
09-21-2010 01:43 AM
Rgds,
Souvik
09-21-2010 03:34 AM
Dear Souvik,
Thanks bro have good explanation, i will try to give this command and then let you know what heppand.
switch(config)#msl qos
switch(config)#int fa1/0/1
switch(config-if)#no switchport
switch(config-if)#ip add 192.168.1.1 255.255.255.0
switch(config-if)#srr-queue bandwidth limit 70
Thanks once again!!!
09-29-2010 12:54 AM
Dear Friend,
I configure "mls qos" command in global mode Cisco 3750 switch and then apply "srr-queue bandwidth limit 70 on int fas0/2
but bandwidth exceed more than 40 mb.
I need 30 mb bandwidth limit on int fast 0/2
swtich(config)#mls qos
switch(config)# int fas0/2
switch(config-if)# ip add 192.168.1.1 255.255.255.0
but still bandwidth exceed more than 40 mb through fas0/2 interface
what config i need to achive this
Thanks in ADV,
08-20-2018 11:39 PM
You need to run "srr-queue bandwidth limit 30" on interface to limit the bandwidth to 30Mbps
