Unity upgrade 4.03 to 7 ADschema update
Sep 21st, 2010
Dear all,
I would like to know if it is possible to run Adschema update for Unity 7.0 when Unity 4.03 still online.
Thank you for your help
Maissiat
Aaron Harrison Tue, 09/21/2010 - 03:05
  • Community Spotlight Award,
    Member's Choice, May 2015
Yes, the schema will be extended further by the 7 version, but nothing that is added will break version 4, and nothing can or will be removed that 4 needs.
So yes, it is safe.
Aaron
Please rate helpful posts...
