VPN concentrator - Admin rights removed
stephendrkw
Level 3
Level 3
VPN 3005 Concentrator - I activated the "User" account with limited access, since applying the change and logging back into the concentrator the "admin" a/c also has limited access! If I login via the command line with the "admin" a/c I get the following:
VPN 3005: Main -> 2
-) Administer Sessions
-) Software Update
-) System Reboot
-) Reboot Status
5) Ping
6) Traceroute
-) Access Rights
-) File Management
-) Certificate Management
10) Back
Obviously I've made a mistake here and saved the config to flash. Is there anyway possible to reset admin rights back to full access?, other than re-setting factory default.
Jennifer Halim
Here is the URL to assist you with VPN Concentrator password recovery:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2284/products_password_recovery09186a008009434f.shtml
Hope that helps.
