cisco 3911 stopped working and cannot boot
Sep 20th, 2010
Hi all,
i used to have 4 3911 in my CUCM 7.1 working fine for 2 weeks!!
I also have 2 spare 3911.
Suddenly, one of them started restarting but not the usual way;         it only shows a cisco logo (i cannot press any button) for 10         seconds and then it turns of and this is happening again.
I use POE to power it.
I replaced it with another spare one, it worked for 2 days and         now it is doing the same thing.
Also, the last 3911 did the same so no spare left now!
Can i hardware restart it or something like this without         accessing the menu of the phone?
they are running SIP3951.8-1-4-0
NEW INFO!!
I have just used a power cube 3 and it works.
I plug it back to the switch and it does nothing! WS-C2960-48PST-S
I plug it in another Catalyst Express PoE and it has also the problem!
What solved the problem!!
removing from the intraface of the 2960 WS-C2960-48PST-S the command:
switchport voice vlan 100
and adding
switchport access vlan 100!!
Have not figured out what must i do about my
CatEx500
running 12.2(25)SEG2
