VPN Users Can Not Access Tunnel
Answered Question
Sep 21st, 2010
Hi All,
I have a problem, I have 2 sites both with ASA 5520's they are both connected via a site to site VPN.
this works fine all users in site A can access resources in site B and vice versa.
The problem comes when a user connects using a remote user VPN to site A they cannot access or ping anything in site B even though the FW issues them an ip in the range for site A.
Im sure there is something simple I have missed.
Correct Answer by Jennifer Halim about 6 years 10 months ago
If the VPN Client pool is in the same subnet as site A LAN, then you probably just missing the following:
1) Double check if you have split tunnel policy, and site-B LAN is included in the split tunnel ACL.
2) Configure "same-security-traffic permit intra-interface" on site A ASA.
If the above has been configured, please share config from both ASA to further check where the issue is.
Overall Rating: 5 (1 ratings)
Correct Answer
Jennifer Halim Tue, 09/21/2010 - 03:52
  • Cisco Employee,
jamesprice141 Tue, 09/21/2010 - 04:08
Excellent thank you, you are a star!
I was missing 2
Schoolboy error, works fine now.
