Printers in LAN
Sep 21st, 2010
I have router VRV200 and I have printer Canon LPB5050n. Would you tell me do I need printserver to have access to this printer by router from each computer without still engaged one?
Addition question is that I can't have wire acces to my router, so what I need to contact my printer with router by wifi line - if is enough to have normal wifi reciver?
Phillip Remaker Tue, 10/19/2010 - 15:37
You mean a WRV200, which is a Linksys product.  Better to ask at the Linksys forums,
The LBP5050n already has an integrated ethernet port, so you can connect the printer to the WRV200 directly.  No print server is needed.
Any device, wired or wireless, can connect across the WRV200 without a problem.  Therefore, all wired and wirelss users can use the printer without using a dedicated print server,
