Gigabyte Module (2GB)
Sep 21st, 2010
Hi everyone,
I need a GigaByte Module (2 GB) that is used for a long distance link connection (SAN).
Do you have the part number of this network module? will glx-sx-mm be appropriate?
Overall Rating: 5 (1 ratings)
Jan.Ferre Fri, 10/08/2010 - 07:04
Now I don't know what a 2 GB module is! But you write a partnumber containing 'sx-mm'!  If this means multimode, I wouldn't put it in the same line as a 'long distance' communication.
Jan Ferré
Tom Randstrom Fri, 10/08/2010 - 07:54
A 2GB module is based on Fiber Channel protocol used for storage networking.
The GLC-SX-MM part number is a 1GB Ethernet, short reach, multimode module... definitely not something I would consider long-reach either!
