Unable to add multiple datasources in IPCC Express
Sep 21st, 2010
I have an IPCC express infrastructure in HA running 4.0(4)SR1.
I configured two datasources in IPCC and created two ODBC connections in each server (tests successfully).
When using the DB Read and Get steps in the editor I am unable to select the second Datasource even after refreshing schema button (the properties menu shows only the first created).
Could you suggest any solution?
Tx,
Lucia
