Share Lines
ali nasser
I have shared line between GM and has 3 secritary when the GM use has line or anyone of has secritary  its appear that line is busy. but when i call the same shared extension i can recevice a call.
what i want is, if any body use this line the second call should be busy.
thanks
11 Replies 11
Jaime Valencia
The maximum number of calls and busy trigger are still defined in a per-device level.
If you don't want anyone to use the line then you need to set the busy trigger to 1 in all of those devices.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
what i mean when some one use the shared line so nobody else can use or receive a call, i set the max trigger 1.
but still i can receive a call working.
Thansk for reply
Then you also need maximum number of calls to 1.
Review the explanation of how settings work.
Devices with shared-line appearance  support the Call Forward Busy Trigger and the Maximum Number of Calls  settings. You can configure Call Forward Busy Trigger per line  appearance, but the configuration cannot exceed the maximum number call  setting for that directory number.
The following example demonstrates how three Cisco Unified IP Phones  with the same shared-line appearance, directory number 2000, use Call  Forward Busy Trigger and Maximum Number of Calls settings. This example  assumes that two calls occur. The following values configuration applies  for the devices:
Cisco Unified IP Phone 1—Configured for  a maximum call value of 1 and busy trigger value of 1
Cisco Unified IP Phone 2—Configured for  a maximum call value of 1 and busy trigger value of 1
Cisco Unified IP Phone 3—Configured a  for maximum call value of 2 and busy trigger value of 2
When Cisco Unified IP Phone User 1 dials directory number 2000 for the  first call, all three devices ring. The user for Cisco Unified IP Phone 3  picks up the call, and Cisco Unified IP Phones 1 and 2 go to remote in  use. When the user for Cisco Unified IP Phone 3 puts the call on hold,  user can retrieve the call from Cisco Unified IP Phone 1 or Cisco  Unified IP Phone 2. When User 2 dials directory number 2000 for the  second call, only Cisco Unified IP Phone 3 rings.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/8_0_2/ccmsys/a03dn.html#wpxref37374
java
java
I will make it more clear see.
     Secretary 1
line 1 - 3186
line 2 - 3100     Max Trigger 1 , Max Call 1
line 3 - 4747     Max Trigger 1 , Max Call 1
     Secretary 2
line 1 - 3502
     Manager
line 1 - 3100     Max Trigger 1 , Max Call 1
line 2 - 4747     Max Trigger 1 , Max Call 1
if secretary 1 is using line 2 it should be busy in manager and secretary 2, and also for incoming when one receive a call in any of these phone the other will give busy tone for the caller.
IS THIS POSSIBLE.
You mean per-line appearance, not per-device, right?
Rob Huffman
Hi Ali,
Yes, if you set the Busy Trigger for 3100 to 1 on all three phones
as you have nicely listed you will achieve your desired result
Cheers!
Rob
I made these changes but still they can receive a second calls in free phone set.
thanks
Hi Ali,
They can receive a second call on 3100? Or on the phone in general?
Cheers!
Rob
HI,
they receive in the line 3100.
thanks
Rob Huffman
Hi Ali,
OK ...first things first
Check to make sure 3100 isn't on any other phones. Then set the  Busy trigger to 1 on each of the 3x
3100 appearances.
line 1 - 3186
line 2 - 3100     Busy Trigger 1 , Max Call 2
     Secretary 2
line 1 - 3502
     Manager
line 1 - 3100     Busy Trigger 1 , Max Call 2
Then test again.
Cheers!
Rob
Its working fine without extension mobility were all the users are not logged in to their device profile. the scenario i have is one manager without extension mobility and his two secretary is using extension mobility and they are logged in to their device profiles.
Manager phone (not using extention mobility)
line 1 - 3100     Partition:Internal      CSS: international
line 2 - 4747     Partition:Internal     CSS: international
Secretary one:
Device configuration:
line 1 - 3186     Partition: none     CSS: internal-CSS
line 2 - 3100     Partition: none     CSS: internal-CSS
line 3 - 4747     Partition: none     CSS: internal-CSS
Device profile configuration(EM):
line 1 - 3186     Partition: Internal     CSS: international-CSS
line 2 - 3100     Partition: Internal     CSS: international-CSS     forward unregistered Internal/External 3100 CSS: none
line 3 - 4747     Partition: Internal     CSS: international-CSS     forward unregistered Internal/External 4747 CSS: none
Secretary two:
line 1 - 3502     Partition: none     CSS: internal-CSS
line 1 - 3502     Partition: Internal     CSS: international-CSS
the requirement is providing secretary with international access (for line 1, line 2, and line 3) only when they are logged to EM and have no access if not. for that i make the line under device profile with Internal partition and none partition under physical device.
the problem is that when a call comes for ext 3100 and one of the secretary is logged in and one is logged out, only the call will come to the manager (partition: none) and the logged in secretary while the logged out secretary will not receive the call.
in summary i found out that the line will ring only if the three users are having same partition.
is there any way to solve this
regards,
Ali
