Suggest a VPN router with Over 30 PPTP connections
Rudresh V Sun, 10/03/2010 - 09:56
  • Cisco Employee,
Hi Majid,
A Cisco router running PPTP can support up to 2000  simultaneous PPTP tunnels without MPPE encryption. For PPTP tunnels  with MPPE encryption, Cisco routers can currently support up to 500  simultaneous tunnels.Following are the platforms that supported PPTP:
Cisco Platforms:
Cisco 1600 series
Cisco 1720 VPN Access Router
Cisco 2500 series
Cisco 2600 series
Cisco 3600 series
Cisco 4000-M series (Cisco 4000-M, 4500-M, 4700-M)
Cisco 7000 series
Cisco 7100 series
Cisco 7200 series
Cisco 7500 series
Cisco AS5200
Cisco AS5300
Cisco AS5800
Windows Clients:
Windows 95/98
Windows NT 4.0
Windows 2000
More info regarding PPTP feature is here: http://www.cisco.com/en/US/docs/ios/12_1t/12_1t5/feature/guide/dt_pptp.html#wp1019895
For the IOS software versions that support pptp connections, please refer to the IOS feature navigator here:
http://tools.cisco.com/ITDIT/CFN/Dispatch?act=featSelect&task=detail&featStartsWith=All
--In the above link, select the feature as PPTP, and then you can see the list of IOS versions supporting the feature.
Let me know if this helps...
Cheers,
Rudresh V
Related Content
