One command for IP addresses and descriptions
Answered Question
Sep 21st, 2010
Hello all,
most of us use the following commands very often:
"show ip interface brief"
"show interface description"
Is there any command, which show interface IP addresses and descriptions?
Can I combine these commands somehow?
Correct Answer by Jennifer Halim about 6 years 7 months ago
This command might be something you are looking for:
sh interface | i line protocol|Internet address|Description
Hope that helps.
Overall Rating: 5 (2 ratings)
Correct Answer
Jennifer Halim Tue, 09/21/2010 - 05:14
  • Cisco Employee,
Hope that helps.
sebastian.lemke Tue, 09/21/2010 - 05:33
ahh, that's it, thanks a lot!
It's not as neat as the output of the other commands, but it works.
I didn't know, that you can combine the "| include" filters... Do you have a website, where this is documented?
Jennifer Halim Tue, 09/21/2010 - 05:47
  • Cisco Employee,
I don't think we have a documentation that includes that specifically, however, I believe it uses the normal regular expression symbols for multiple matches.
