ASA 5520 Memory
Sep 21st, 2010
i understand that ASA 5520 is coming with default 512MB memory on it. is there an option to upgrdae the memory?, if it can, waht is the maximum memory i can get and what is the part number for it ?
thanks,
Maykol Rojas Wed, 10/20/2010 - 17:50
Hello Avi,
Here you will find the memory upgrade kits to run the latest version
Table 2     DRAM Upgrade Kits
Model
Size
Part Number
ASA 5505
512 MB
ASA5505-MEM-512=
ASA 55101
1 GB
ASA5510-MEM-1GB=
ASA 5520
2 GB
ASA5520-MEM-2GB=
ASA 5540
2 GB
ASA5540-MEM-2GB=
1 If you previously purchased the 512MB upgrade kit for the ASA 5510 (ASA5510-MEM-512=), you must upgrade to the 1 GB memory upgrade it to run Version 8.
Taken from
http://www.cisco.com/en/US/docs/security/asa/asa83/release/notes/asarn83.html#wp322273
Cheers
Mike
