UCCX 8 Custom report - stored procedure
Sep 21st, 2010
  • Bronze, 100 points or more
I'm porting over a custom UCCX 5 historical report to UCCX 8. I'm trying to port the stored procedure to informix but some of the helper routines such as getRoutingSkills(), getRestrictedDate() and parse2() are all restricted and I don't have permission to grant access to the report user.
A call to one of these functions generate the error message "SQL Error (getrestricteddate) cannot be resolved."
I'm logging in to the informix database with the uccxhruser account and I don't know of any other account with elevated privilege that I can use for development.
My question is there any documentation on security requirements for creating stored procedures for UCCX 8? What do i need to do to gain access to the functions listed above? Do i need to re-create these helper routines myself?
Please advise.
Chris
chrismanuh Wed, 09/22/2010 - 09:56
I've noticed there's a database user named "uccxuser" with privilege set to "DBA".  I believe this is the account i should be using to create my stored procedures but I don't know the password to it.  Does anyone know how custom stored procedures should be created on uccx 8's database and which account we should be use?
Chris
