09-21-2010 07:09 AM - edited 03-04-2019 09:50 AM
I have been asked for any performance/latency differences between these 2 but i can not find anything on the net or on the website so thought i would ask here. Hope someone knows!!!!
Cheers
09-21-2010 08:38 AM
Is this what you are looking for:
Cisco X2-10GB-SR
09-21-2010 08:47 AM
Hi anthony,
I do not think there is any performance difference between the 2 , they are both 10 Gig - sr.
I think the only difference is the form factor, X2 is the wider transceiver (like a GBIC) and i think it should be SFP+ which is the size of an SFP.
Please correct me if i am wrong
Br
Dimitri
09-21-2010 08:53 AM
Yep, All i could find was the only reason to have the transformer was if one type was not available or the client wanted to have the same throughout their solution. Went through all teh data sheets so like you i concluded there were no performance or latency differences between the two.
