WAP4410N compatible with HGA9N High-Gain Omnidirectional
Sep 21st, 2010
Hello Everyone
Requesting you help will WAP4410n accept a HGA9N high gain antenna, I know the connector are different since the HGA9N has a N-type connector and the access point has R-SMA three connections, but wondering if purchasing a cable of about 150 ft. R-SMA to N-type would actual do the job for outdoors which is where the HGA9n antenna will be installed.  Any ideas let me know or if it even works.
stownsend Wed, 01/30/2013 - 07:53
I'm looking into a Similar solution, did you come up with something?
Related Content
