LMS 3.2. Error in Job
Sep 21st, 2010
hello,
We get this error when this job run.
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Tabla normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}
Device
Commands
X.X.X.X
set cam notification enable
set snmp trap enable macnotification
set cam notification added enable Gi1/0/8
set cam notification removed enable Gi1/0/8
set cam notification added enable Gi1/0/10
*** Device Details for X.X.X.X ***
Protocol ==> Unknown / Not Applicable
Selected Protocols with order ==>   SSH,Telnet
Execution Result:
CM0107 Import the config file to PRIMARY   Running Config on device failed Cause: CM0070 Copy Config to device failed on   X.X.X.X Cause: TELNET: Failed to establish TELNET connection to   X.X.X.X - Cause: Connection refused.
Action: Check device credentials and   reachability.
CM0089 Config archival successful for X.X.X.X
This is the credentials verification report.
Credential Verification report as on Sep 08 2010     17:02:16 CEST
Run     now
Device Name
Read Community
Read Write Community
SNMPV3
Telnet
Enable by Telnet
SSH
Enable by SSH
X.X.X.X
OK
Failed
No Value To Test
Failed
Did Not Try
OK(Primary Successful)
What can be the problem?
Joe Clarke Tue, 09/21/2010 - 23:24
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
There is not enough information here to determine the root cause.  You would need to provide debug logs to determine the cause of the failure.  Since SSH appears to be working, it could be that these commands return an error code.  If you cannot provide the logs here, open a TAC service request and attach the logs for this job.
