Create multiple Profiles Anyconnect 2.5?
Sep 21st, 2010
I'm trying to create 2 anyconnect profiles on a laptop.
One to connect to one connection profile with an access list applied and one without an access list applied.
I'd like to allow the users to be able to click on one icon and connect with one profile and click the other to
allow access to the other profile with no access list.
Is there a way to do this? I'm using asdm 6.3 with profile editor.
Sam
adhar Tue, 09/28/2010 - 18:00
Not sure about your exact requirement. But if you use anyconnect alias you can have two profiles and provide the alias (link) to the user. Users will get the profile based on the link.
