DHCP on 3750 for network not connected switch
vragotha Tue, 09/21/2010 - 20:15
Configure the DHCP pool on the 3750 as you would normally. The connected devices between the 3750 and the clients need to have an IP helper set. Can you post a network topology?
Here is scrubbed config on the switch I am using.
aaa new-model
aaa authentication login default group tacacs+ local
aaa authentication enable default enable
aaa authorization exec default group tacacs+ local
aaa accounting send stop-record authentication failure
aaa accounting update newinfo
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 1 default stop-only group tacacs+
aaa accounting commands 15 default stop-only group tacacs+
aaa accounting network default start-stop group tacacs+
aaa accounting system default start-stop group tacacs+
aaa session-id common
clock timezone EST -5
clock summer-time EST recurring
switch 1 provision ws-c3750g-24ts-1u
switch 2 provision ws-c3750g-24ts-1u
system mtu routing 1500
vtp mode transparent
authentication mac-move permit
no ip subnet-zero
no ip source-route
ip domain-name dtsrv.local
ip dhcp excluded-address 10.3.3.1
ip dhcp excluded-address 10.2.2.1
ip dhcp pool Employee_Remote_Access
   network 10.3.3.0 255.255.255.0
   default-router 10.3.3.1
ip dhcp pool Employee_Local_Access
   network 10.2.2.0 255.255.255.0
   default-router 10.2.2.1
spanning-tree mode pvst
spanning-tree etherchannel guard misconfig
vlan internal allocation policy ascending
vlan 102
name Employee_Local_Access_10.2.2.0
vlan 101
name Towards_ASA_10.1.1.0
interface Vlan102
ip address 10.2.2.1
interface Vlan101
ip address 10.1.1.1
ip default-gateway 10.1.1.1
ip classless
no ip http server
no ip http secure-server
Message was edited by: [email protected]
