Error while saving the conf in switch
Sep 21st, 2010
hi guys...
while saving the running conf to startup conf in 2950 switch, it shows an message is that "configuration buffer size ful.cant add command:l".
%aborting save.compress the config. (ok)?
what can i should do?
i attached the error message with this discussion.
Leo Laohoo Tue, 09/21/2010 - 16:54
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Answer "yes".  This is a bug.
vragotha Tue, 09/21/2010 - 17:49
  • Silver, 250 points or more
Can you post a 'dir nvram:' and 'show run' ?
The size of your running config may be bigger than the 32KB nvram
jorge.calvo Tue, 09/21/2010 - 23:46
  • Bronze, 100 points or more
It seems you running-config file is bigger the default 32KB of NVRAM memory.
You should be able to solve it using the next global config command:
"boot buffersize " i.e "boot buffesize 64000 " (Note the switch needs to be reloaded).
Hope this helps.
