Channel Group configuration on E1 PRI
Answered Question
Sep 21st, 2010
Hi All,
With reference to below mentioned diagram, i have configured channel group on e1 controller and trying to pass data on this link and works fine. So my question over here is for such kind of requests is service provider does one to one maping of all 31 channels over his network from one end to other end of PRI for ever?
Mangesh Bhende
Correct Answer by Giuseppe Larosa about 6 years 7 months ago
Hello Mangesh,
E1 is part of SDH and PDH time division multilpexing and it is very useful in voice networks ISDN PRI is still a key element even in VOIP scenarios.
IT is not intended as a cheap alternative to leased lines, of course there can be cases where it can  be cheaper but not generally speaking
Hope to help
Giuseppe
Hello Mangesh,
yes you can see it in this way. PRI is structured and the provider is carrying the whole E1 over SDH
Hope to help
Giuseppe
Overall Rating: 5 (2 ratings)
Correct Answer
Giuseppe Larosa Mon, 09/27/2010 - 08:37
  • Hall of Fame,
    Founding Member
Hello Mangesh,
Hope to help
Giuseppe
mangesh-bhende Wed, 09/29/2010 - 01:08
Thanks for your reply, under which scenario such kind of circuits are ordered compared to Lease line and is it cost effective?
Mangesh
Correct Answer
Giuseppe Larosa Wed, 09/29/2010 - 05:48
  • Hall of Fame,
    Founding Member
Hello Mangesh,
Hope to help
Giuseppe
