Local preference of zero
Sep 21st, 2010
  • Silver, 250 points or more
Hi experts,
I am having one customer connected to our MPLS PE. we face strange problem of some of the prefix is showing local preference
of zero which is strange b'se no such policy (route-map) is applied to the bgp peering with that customer.
providing few output from PE end
Router#sh run vrf ABC
ip vrf ABC
rd x:x
export map EXPORTS-MAP
route-target export x:x
route-target import x:x
maximum routes 10000 80
router bgp 9498
address-family ipv4 vrf ABC
  no synchronization
  bgp dampening 5
  redistribute connected route-map SET-COMMUNITY-CONNECTED
  redistribute static route-map SET-COMMUNITY-STATIC
  neighbor x.x.x.2 remote-as 9730
  neighbor x.x.x.2 activate
  neighbor x.x.x.2 as-override
  neighbor x.x.x.2 prefix-list ABCD in
exit-address-family
interface Serial2/0/1.6 point-to-point
ip vrf forwarding ABC
ip address x.x.x.1 255.255.255.252
end
Router#sh ip bgp vpnv4 vrf ABC 10.140.63.0/26
BGP routing table entry for x:x:10.140.63.0/26, version 160176610
Paths: (1 available, best #1, table ABC)
  Advertised to update-groups:
    x.x.x.2  from x.x.x.2
      Origin IGP, metric 0, localpref 0, valid, external, best
      Extended Community: RT:x:x
      mpls labels in/out 4416/nolabel
Please let me know if someone has faced similar problem. local pref should be 100 by default but here it seems to be something strange
thanks in advance
Overall Rating: 5 (1 ratings)
milan.kulik Wed, 09/22/2010 - 01:18
  • Red, 2250 points or more
it's also strange I see
while you are having
in your config.
Doesn't the customer use something complex like Route Reflectors to Exchange VPNv4 Routes
(http://www.cisco.com/en/US/docs/ios/12_0s/feature/guide/fsiasl22.html#wp1030302 )
in his network?
BR,
Milan
Mahesh Gohil Wed, 09/22/2010 - 02:48
No, it is not correct,
I have changed output you can consider it as 9730.
But it seems this is malfunctioning of router and strange.
let me see if someone has faced similar problem or i will log tac case
thanks for your reply
mahesh
Mahesh Gohil Tue, 11/02/2010 - 00:57
Well guys there is update may be helpful to others
it is declared as bug by cisco: CSCtj23145
and this happens for vrf where we have used export-map  and the workaround is to add one more statement in route-map with LP=100
like
route-map permit 40
set local-preference 100
Mahesh
