What is this command for?
Answered Question
Hello there,
Can I know what is this command for, "ip bgp-community new-format" ? If I am not using BGP community string, do I need to enable this command?
Correct Answer by Peter Paluch about 6 years 6 months ago
Chris,
This command changes the way the community string value is displayed in various reports. It does not modify the binary format of the community string as sent in BGP messages. It is purely about how you see the community value displayed in, say, various show ip bgp commands.
For detailed information about this command, see the following link:
http://www.cisco.com/en/US/docs/ios/iproute_bgp/command/reference/irg_bgp2.html#wp1093343
Using it does not harm even if you are not using communities.
Best regards,
Peter
Overall Rating: 5 (2 ratings)
Correct Answer
Peter Paluch Wed, 09/22/2010 - 00:53
  • Cisco Employee,
Chris,
Best regards,
Peter
