IPS Signature licensing
Answered Question
Sep 22nd, 2010
I am going to configure IPS on a C2921 ( /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Tabel - Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;} c2900-universalk9-mz.SPA.150-1.M2.bin ) for a customer. The customer has the security license.
But when I look at the Cisco Feature Navigator I can see that it says additional license required: IOS IPS update.
So do I really need another license in order to configure and use IPS?
If yes, how can I get that license?
Laurent
Correct Answer by Jennifer Halim about 6 years 5 months ago
IPS Subscription can normally be purchased through reseller, similar to how you normally purchase Smartnet contract.
Overall Rating: 5 (1 ratings)
Jennifer Halim Wed, 09/22/2010 - 02:34
Absolutely correct. You would need to purchase the IOS IPS license to be able to update the signatures. You don't need license to use and configure the IOS IPS, however, you would need license to update the signatures to the latest signature packs.
The license will be called IPS Svc (IPS Subscription).
Hope that helps.
Correct Answer
Jennifer Halim Wed, 09/22/2010 - 03:13
