AAA Authentication Failed
Sep 22nd, 2010
Hi Experts,
I face some problem when try to login router using AAA authentication. Then the router get the local password to login.
I paste below the result after debugging AAA authentication:
*Sep 22 15:43:32.194: AAA/BIND(000115D0): Bind i/f
*Sep 22 15:43:32.198: AAA/AUTHEN/LOGIN (000115D0): Pick method list 'default'
*Sep 22 15:43:56.010: %RADIUS-4-RADIUS_DEAD: RADIUS server 192.168.3.251:1645,1646 is not responding.
*Sep 22 15:43:56.010: %RADIUS-4-RADIUS_ALIVE: RADIUS server 192.168.3.251:1645,1646 is being marked alive.
*Sep 22 15:43:56.010: AAA/AUTHEN/LINE(000115D0): GET_PASSWORD   ----> authentication failed then router find local password
*Sep 22 15:44:19.330: AAA/AUTHEN/LINE(000115D0): PASS
I need your expertise.
Thanks.
Vinay Sharma Wed, 09/22/2010 - 05:21
  • Gold, 750 points or more
Hi Muhammad,
It seems to be some config issue to me.Since the config is not avilable, just have a look at this sample config.
aaa new-model
aaa authentication ppp default group radius
aaa authorization network default group radius
aaa accounting network default start-stop group radius
radius-server host X.X.X.X auth-port 1812 acct-port 1812
radius-server key testradius
If the device you are testing is a test device, try to make the changes and share the results.
If still face the issuem, collect the following debugs:-
debug aaa authentication
debug aaa authorization
debug radius
thanks,
Vinay
