Problems with the Acknowledged propertie in the WCS
Answered Question
Sep 22nd, 2010
I have a problem with the ACK propertie in the WCS. I check a logg entrie in the logg with the ACK, in few seconds/minute/hour this alarm disappear, and then if this alarm appear again, this message show the ACK marked.
Should not receive the message again without the ACK marking? what is the problem?
Thanks in advanced
Correct Answer by Federico Ziliotto about 6 years 3 months ago
According also to what is stated in the official guides, this seems to be the expected behavior:
"You can acknowledge the  alarm to prevent it from showing up in the Alarm Summary page. The alarm  remains in WCS and you can search for all Acknowledged alarms using the  alarm search functionality."
http://www.cisco.com/en/US/docs/wireless/wcs/7.0/configuration/guide/7_0event.html#wp1229996
So you can acknowledge that specific alarm once to not show it in the alarm page anymore, only for that occurrence. If however the alarm occurs again, the new occurrence will show up and let you know that you previously acknowledge a similar instance.
Hope this clarifies the behavior,
Fede
If this answers your question please mark the question as "answered" and rate it, so other users can easily find it.
Overall Rating: 5 (1 ratings)
Correct Answer
Federico Ziliotto Thu, 10/14/2010 - 01:14
Fede
