Check if a DDI number is reaching the gateway
Answered Question
Sep 22nd, 2010
We have a problem with some DDI's just getting a dead tone when we call them. I'm fairly certain it is a problem at the telecom companies end but wanted to be sure. Is there a command I can use to view live calls hitting the gateway? I basically want to try dialling the numbers in question and see whether or not they are hitting our gateway.
Gateway is h.323 not MGCP.
Steve
Correct Answer by Brad Martin about 6 years 6 months ago
If you have a pri circuit "debug isdn q931" will show active calls. If not "debug voip ccapi inout" will get you plenty of info on inbound calls.
Overall Rating: 5 (1 ratings)
Correct Answer
Brad Martin Wed, 09/22/2010 - 06:13
  • Bronze, 100 points or more
