Vinay Sharma Wed, 09/22/2010 - 05:29
Hi k abillama,
Make sure you have connected to port 6 because port 2 and 5 are the (Blocked) Gigabit Ethernet.
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_system/5.1/installation/guide/csacs_hw_ins.pdf
As you said that it worked initially but stop working after reload, it could be a hardware issue as well if the conneciton has been made as per document mentioned.
thanks,
Vinay
k.abillama Wed, 09/22/2010 - 07:12
Hi vinashar,
I double checked and it's correct! During the initial setup it was working but then and after reloading the appliance it didn't work anymore. The other interface is working normally. Could it be a bug?
