Throttling Host Bandwidth on Layer 2 Access Switch?
Answered Question
Sep 22nd, 2010
Is there a way to limit bandwith on an access port? For example based on the configuration below:
interface fastethernet0/1
description Server
switchport mode access
switch acc vlan 10
speed 100
duplex full
spanning-tree portfast
I'm familiar with rate limiting and QoS at the layer 3 level, but would like to do it at the switch port level.
Thanks in advance.
Correct Answer by Julio Garcia about 6 years 4 months ago
hi David,
This is how i do it ...
make a policy
policy-map 10Mbps-LIMIT
  class class-default
   police cir 10000000 bc 1000000 be 1000000 conform-action transmit exceed-action drop
then on layer 2 switch port..
int x/x
service-policy input 10Mbps-LIMIT
one caveat, i think you can only do in (IN) direction only
im not an expert by any means , but i spent ages trying to find a way that actually works.
try it out and let me kno.
Correct Answer by Lei Tian about 6 years 4 months ago
Check 'Campus QoS Design' section in this doc.
http://www.cisco.com/en/US/docs/solutions/Enterprise/WAN_and_MAN/QoS_SRND/QoSDesign.html
The untrust model configuration has examples of policing.
HTH,
Lei Tian
Overall Rating: 5 (2 ratings)
Lei Tian Wed, 09/22/2010 - 05:47
Most switches support ingress policing on physical access port; what platform are you using?
Lei Tian
davidhuynh5 Wed, 09/22/2010 - 10:55
Cat3560, Cat4506, and Cat6506. Sample config wuold be appreciated. Thanks.
Correct Answer
Julio Garcia Wed, 09/22/2010 - 14:40
hi David,
make a policy
  class class-default
int x/x
