dap, traffic from lan to vpnclient
Sep 22nd, 2010
Hi all,
I am configuring an ASA5510 8.2(1)11 to use dap to permit remote access using ipsec vpn client.
Everything is ok except when I try to connect from the LAN to the client.
I receive a message of Authorization denied for user 'unknown' because of the DAP applied to the vpn connection.
How can I permit connection?
Rahul Govindan Wed, 09/22/2010 - 11:10
  • Silver, 250 points or more
what is the DAP policy that you are currently using. please post the output of debug dap menu 2 . Also wat does the debug dap trace show you. That should show which dap policy is being hit during login.
gdspa Fri, 09/24/2010 - 00:44
This is the log I have:
6    Sep 24 2010    09:39:32    109025    Server    1648    10.26.0.2    9595    Authorization denied (acl=DAP-ip-user-0076860E) for user '' from Server/1648 to 10.26.0.2/9595 on interface inside using TCP
where 10.26.0.2 is the ip address of the vpnclient.
In the dap I added an acl that permits traffic from the Server to the vpnclient network, and from dap trace I see that this acl is applied to the connection.
What do you mean with debug dap menu 2 ?
Related Content
