We are using cisco 7000series,2mbps E1 is connected point to point,getting Serial interface reset Line protocol down.Need to know where is the issue?
Sep 22nd, 2010
Mahesh Gohil Thu, 09/30/2010 - 02:49
  • Silver, 250 points or more
Hi swamy,
I have taken below output from cisco tool: output interpreter, may be useful to you
Interface Serial1/0:1 (reset/down)
  WARNING: This interface has the status as reset.
  This is a hardware-related issue, such as, a defective smart jack, demarcation
  cable or controller, or a physical connection failure. This problem can occur
  if packets queued for transmissions are not sent for several seconds. Also, this
  issue may be caused when a modem does not supply the transmit clock signal, or
  when there is a cable problem. Whenever the Carrier Detect signal of the serial
  interface is up, and the line protocol is down, the IOS device periodically resets
  the interface in an effort to restart it. Interfaces can also be reset when they
  are looped or shut down.
Mahesh
kumar_s29 Thu, 09/30/2010 - 21:45
Hi Mahesh,
Will that reset status automatically gets changed to UP?
