Showing results forĀ
Search instead forĀ
Did you mean:Ā
How to find certain "network-object" belong to which "object-group"?
Adam David
Let say I want to find which access-list is using ip address 10.10.10.10
I start the searching by issue sh run | i 10.10.10.10
ASA5520# sh run | i 10.10.10.10
name 10.10.10.10 net-ABC
Then I found  ip address 10.10.10.10 is mapped to net-ABC
I run sh run | i net-ABC command to find which access-list is using it and I got this output.
ASA5520# sh run | i net-ABC
network-object net-ABC 255.255.255.248
Is there any command to filter network-object net-ABC belong to any object-group?
Yes, I can find this by using command sh run object-group. This command is very useful if there are not many object-group. However, it's hard to filter if there are a lot of object-group in the firewall.
ASA5520# sh run object-group
object-group network net-XYZ
network-object net-DEF 255.255.255.248
Thanks in advance
Nagaraja Thanthry
You can try the following:
Turn off the "names" feature so all names are converted to IP addresses in the configuration:
"no names"
show access-list | i 10.10.10.10
show run | i 10.10.10.10
show run object-group | be 10.10.10.10
Once you are done with finding the information, turn on the names
"names"
Hope this helps.
NT
