CUPC Interoperability with MS Outlook 2003
Sep 22nd, 2010
i have an interoperability problem with CUPC and MS outlook 2003. I installed CUPC version 7.1.1 once the outlook starts it crashes. i found that the problem is from windows outlook updates once unistalled the CUPC works, but once reinstalled the outlook crashes again.
Enclosed outlook crash.
Any ideas please!!!
Thanks!
MatniBassam Wed, 09/22/2010 - 06:31
These are the outlook updates that are causing it to crash, i forgot to add them in the previous post:
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman","serif";}
  • Security Update for Outlook 2003 (KB980373): Outlook
  • Security Update for Outlook 2003 (KB2293428): OLKINTL
Thanks!!!
Joseph Martini Thu, 09/23/2010 - 11:35
  • Cisco Employee,
Thank you for following up and posting the solution.
