09-22-2010 07:16 AM - edited 03-11-2019 11:43 AM
I have a task of replacing PIX515E ver 6.2(2) to ASA 5505. I have read that I need to upgrade PIX to ver 7.0 before I can just use tftp and move the config to ASA. However, if I dont have an option to upgrade what is the best way to go about it? Is the only option, to just configure ASA from scratch?
Solved! Go to Solution.
09-22-2010 07:58 AM
There is a tool available to convert PIX configuration to ASAs. You can download the same from the link below:
http://www.cisco.com/cgi-bin/tablebuild.pl/pix
Hope this helps!! Please note that there are a few commands that will not be migrated, for example, conduits.
Thanks and Regards,
Prapanch
09-22-2010 07:58 AM
Thanks and Regards,
Prapanch
09-23-2010 04:24 PM
Thanks Prapanch!! After looking at the instructions for the conversion tool, I think I will have to upgrade PIX to ver 6.3 and then use the tool to do the migration to ASA 5505. I will also have to regenerate the certificates on the ASA as PIX 6.3 will not copy the certificates to the ASA directly.
The other option is to do the conversion manually.
If I do the conversion using the tool and upgrading the pix ver to 6.3, are there any other major reasons I need to be concerned of?
Thanks!
09-23-2010 05:29 PM
As i mentioned, there are few commands such as conduits in 6.3 which are not migrated using the tool. When you perform the migration, you will see a list of commands that aren't migrated as well. You can check that and make the necessary changes then and there before putting the converted config onto the ASA.
Thanks and Regards,
Prapanch
09-30-2010 10:14 AM
Thanks Prapanch. I will try it out.
