Incoming Call Notification Popup for CUPC and IdentaPop Pro
Sep 22nd, 2010
Afternoon all,
We use an application called IdentaPop Pro which is a Caller ID desktop popup program that utilises the Call Manager's TSP drivers. Since we upgraded our CUCM Cluster to 7.1(3)SU2 (from 6.1(4) ) I have noticed that incoming calls on the desktop are popping up with the '0' removed from the beginning of the number..
I have also noticed that the notification popup in Cisco Personal Communicator also removes the zero from an incoming external number.
However, the notification popup works properly if I use IP Communicator and displays the full number correctly.
Do I need to setup any application dialing rules maybe?
Any assistance would be appreciated.
Jamie
Joseph Martini Thu, 09/23/2010 - 11:33
  • Cisco Employee,
CIPC uses SCCP while the TSP and CUPC (in deskphone mode) rely on CTI.  There may have been a change to the TSP between versions that causes that behavior change.  If you would really like to have the old functinality back I'd open a TAC case to reproduce the behavior on the 6.1.4 TSP and the 7.1.3 TSP or even easier just use CUPC.
Related Content
