ip nat inside source list with loopback overload specified
Brett.Cohen
For the command:
"ip nat inside source list 110 interface Loopback0 overload"
I understand that my access list 110 specifies which IP addresses will be considered as a NAT source, but what does Loopback0 overload mean?
Please try the following:
interface Serial0/0.1 point-to-point
description --- To bxxx517 - S3/0/1.76 - CIR 128K - EIR 0
ip address 107.209.66.170 255.255.255.252
no ip nat outside
ip nat enable
frame-relay interface-dlci 526
  class COS-OUT-S0/0.1
interface FastEthernet0/0
description ---
ip address 10.215.100.17 255.255.255.0
no ip nat inside
ip nat enable
interface Loopback0
ip address 64.1.1.1 255.255.255.255
ip nat enable
no ip nat inside source list 110 interface Loopback0 overload
route-map OUT
match ip address 110
access-list 110 permit ip any 107.1.26.0 0.0.0.127
access-list 110 permit ip any 107.30.127.128 0.0.0.127
access-list 110 permit ip any 107.30.144.0 0.0.0.127
access-list 110 permit ip any 107.30.144.248 0.0.0.7
access-list 110 permit ip any 107.30.170.0 0.0.0.255
access-list 110 permit ip any 107.30.171.0 0.0.0.255
access-list 110 permit ip any 107.1.27.0 0.0.0.31
access-list 110 permit ip any 107.1.27.32 0.0.0.31
ip nat source route-map OUT interface Loopback0 overload
Hope this helps.
NT
Nagaraja Thanthry
All source addresses of the packets that match access-list 110 will be converted to Loopback 0 IP address when exiting the router.
If the original source was 192.168.1.1 and the loopback address was 64.1.1.1, then when the packet goes out of the router, it will have a source IP of 64.1.1.1. The source port will also be changed to a random port as assigned by the Router.
Hope this helps.
NT
Hi Nagaraja,
That seems to make perfect sense. And it seems to work the same way as an IP NAT INSIDE SOURCE STATIC command.
But it does not seem appropriate for my design !
The way it is supposedly working in my current design is that when on incoming packet is received at my router Serial (WAN) interface (defined as IP NAT Outside) from a source address of 107.30.127.240 (first octet changed for anonymity), the source address is supposed to appear as the loopback address of 64.1.1.1
ip nat outside
description ---
ip nat inside
Loopback0 address 64.1.1.1 255.255.255.255
Any comments?
Thanks, Brett
no ip nat outside
ip nat enable
description ---
no ip nat inside
ip nat enable
interface Loopback0
ip nat enable
route-map OUT
Hope this helps.
NT
