AP Operational Status "Downloading"
Sep 22nd, 2010
I have 2 AIR-AP1232AG-A-K9, and their operational status show as "Downloading". They are not connected to the network anymore. How can I remove these two APs from the WLC (5508, Software Version 7.0.98.0) so that they no longer appear in the controller?
Ercan
Serge Yasmine Fri, 10/08/2010 - 03:58
  • Cisco Employee,
Hi Ercan,
Are you 100% sure that they are not on the network anymore and that they have been disconnected?
Serge
ercanelibol Fri, 10/08/2010 - 05:48
Hi Serge,
yes they are not on the network anymore and they are disconnected.
thanks
Serge Yasmine Fri, 10/08/2010 - 06:03
  • Cisco Employee,
Hi Ercan,
I haven't seen anything like this one yet:
Can you telnet to the WLC and do
(Cisco Controller) >config ap reset YOURAPNAME
Will that make the APs go away?
Serge
ercanelibol Fri, 10/08/2010 - 06:15
No it does not.
Even though I can see the ap name in the controller, it gives error message "Cisco AP name is invalid." when I try "config ap reset YOURAPNAME".
Ercan
Serge Yasmine Fri, 10/08/2010 - 06:26
  • Cisco Employee,
Best way to proceed is to open a TAC case here for further investigation or maybe someone else on the forum can come up with some further ideas.
Serge
Surendra BG Fri, 10/08/2010 - 21:27
  • Cisco Employee,
Hi Ercan,
I have seen this issue once.. not sure if you have tried to upgrade the WLC software and after that we are facing this issue.. when we are using 1231 converted APs, then there is chance of APs losing the SSC.. the SSC gets corrupted while upgrade..  i saw this issue on one of the customer scenarios.. so we converted the 1231 AP to autonomous and then reconverted the AP to LWAPP and it joined without any issues.. (WLC used in my case was 4404)
Surendra
Trending Topics - Security & Network
