[HELP] hard reset cisco 1720
Sep 22nd, 2010
How to hard reset on cisco 1720?.
I can not reset the configuration from the console. I see everything on the console but can not run command prompt does not enable me to write.
Now I read many manuals and tutorials. But none helped me to reset it.
Is there any way to reset the hardware configuration? for instance when resetting the bios of the mother.
Sorry my english, i use google translate. I'm only speaking spanish.
Nagaraja Thanthry Wed, 09/22/2010 - 20:01
It looks like your "ScrLK" is on. Can you hit "ScrLK" button on your keyboard once and then try again? You should be able to configure it now.
NT
