Showing results forĀ
Search instead forĀ
Did you mean:Ā
NAT doubt in ASA
bapatsubodh
Is it possible to change the source IP and the target IP of the same  packet that arrived on any of the ASA interface? ( in this case outside )
For example if a packet is reveiced on outside I/F:
soure - a.b.c.d
destination : p.q.r.s
change the source and destination both
source  : a1.b1.c1.d1
Destination : p1.q1.r1.s1   and send it to inside interface.
When packet is retuned  replace the source and destination IP with the original IP and send it back to outside interface.
Is this possible. Any docuemnt or example on cisco.com.
Thanks in advance,
Subodh
mirober2
Hi Subodh,
You can setup something like this:
static (inside,outside) p.q.r.s p1.q1.r1.s1 netmask 255.255.255.255
static (outside,inside) a1.b1.c1.d1 a.b.c.d netmask 255.255.255.255
Hope that helps.
-Mike
mirober2
Hi Subodh,
Hope that helps.
-Mike
Thanks for your prompt reply. Do we have any support document on cisco.com or an example on cisco.com that can show this situation.
Subodh
Hi Subodh,
Here is the configuration guide that shows how to do this with an example:
http://www.cisco.com/en/US/docs/security/asa/asa82/configuration/guide/nat_static.html#wp1064057
-Mike
