09-22-2010 09:35 AM - edited 03-06-2019 01:07 PM
Hi All,
i keep getting into romon for some reason on my C888, the following is an output i really need help doing the Security test in 1 mnth and need to use the CCP and this is the only router, Trued Confreg 2102,2101 still keeps booting into Rommon any else have any ideas?
rommon 22 > reset
System Bootstrap, Version 12.4(15r)XZ2, RELEASE SOFTWARE (fc1)
Copyright (c) 2008 by cisco Systems, Inc.
C880 platform with 262144 Kbytes of main memory
Upgrade ROMMON initialized
loadprog: bad file magic number: 0x0
boot: cannot load "flash:"
rommon 1 >
Thank you
Pat
09-26-2010 09:06 AM
Hello.
It looks like there's no image present in Flash. If there is one, it is probably corrupted. You need to follow the instructions from the link below in order to load new ios provided you have a valid CCO account:
Hope this helps.
09-26-2010 01:03 PM
I also had a problem like this. My IOS was corrupted, so I downloaded another file, and I uploaded it with TFTP.
Just type in the following in rommon mode:
IP_ADDRESS= ip_address
IP_SUBNET_MASK= ip_address
DEFAULT_GATEWAY= ip_address
TFTP_SERVER= ip_address
TFTP_FILE= filename
tftpdnld
it'll take 5-10 minutes. Unfortunately slower than global conf mode.
Regard
Adam.
09-27-2010 03:56 AM
“Thank you for your question. This community is for Cisco Small Business products and your question is in reference to a Cisco Elite/Classic product. Please post your question in the Cisco NetPro forums located here:
This forum has subject matter experts on Cisco Elite/Classic products that may be able to answer your question.”
THANKS
09-28-2010 08:26 AM
Do a "dir flash:" and see if you have a valid image installed. If not, install one with TFTP per the link provided by a previous poster.
09-28-2010 10:01 AM
Thank you that has Answered, it has worked.. urghhhh thank yo again for all the help./
