CallManager Conference
Answered Question
Sep 22nd, 2010
I have a CallManager 7.X running on the Cisco MCS-7845 platform. My question is how many internal conferences are supported with this platform?
Correct Answer by Steven Holl about 6 years 10 months ago
Are you talking about the amount of conferences using the software conference bridge directly on CM?  If so:
Cisco Conference Bridge Software
Software conference devices support G.711 codecs by default.
The maximum number of audio streams for this type equals 128. With 128  streams, a software conference media resource can handle 128 users in a  single conference, or the software conference media resource can handle  up to 42 conferencing resources with three users per conference.
Caution If  the Cisco IP Voice Media Streaming Application service runs on the same  server as the Cisco CallManager service, a software conference should  not exceed the maximum limit of 48 participants.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/7_1_2/ccmsys/a05mtp.html
If you have hardware conference bridges (IOS-based) then the limit is based upon how many sessions you have confiugred under your conference bridge DSPfarms.
Correct Answer by Jaime Valencia about 6 years 10 months ago
The included SW CFB supports up to128 streams.
How many conferences depends on the value for these CUCM parameters:
Maximum Ad Hoc Conference
Maximum MeetMe Conference Unicast
How many conferences you can have is
128/ above parameters = # of concurrent conferences for each type.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
Overall Rating: 5 (2 ratings)
Correct Answer
Jaime Valencia Wed, 09/22/2010 - 10:45
  • Cisco Employee,
  • Hall of Fame,
    2011
java
Correct Answer
Steven Holl Wed, 09/22/2010 - 10:47
  • Cisco Employee,
