how to disable dialer retries
Sep 22nd, 2010
Is there a way to disable the dialer from retrying back a number?
I want our dialer to dial a number and if is a RNA or Busy to close the record and move on, I don't want it to try later.
thanks
david.macias Wed, 09/22/2010 - 10:43
  • Blue, 1500 points or more
That should be set in the config manager under campaign.  Set the max number of attempts to 1.
david
