WAN card problem, Frame relay PVC doesnt come up.
Answered Question
Sep 22nd, 2010
I am trying to install two Serial 2T cards into a 3745 router (R3 in this diagram), all with smart cables to its neighbor. All the devices involved are in one room. One card has no problem with finding its two CDP neighor. The other, which i am trying to set as Frame-relay connections to others, connected to another 3745 that is used as Frame-relay switch.
R2==Serial port on WIC 2====R3=====Serial port on WIC 1(problematic link)==Frame Switch(3745 similated)======R1
|=====Same card ===============================|
Problem: Interface on R3 to Frame Switch is alway up/down, when configured with Frame-relay encapsulation(the same linke, when I set it as hdlc on both sides, it works fine. ). But R1 and R2 are working fine. they are same routers, cards.
Anyone can give me some hint? It seems that there is no much documents online for this.
Also, a second question, the numberation of the ports seems to be very confusion, it doesnt go with the physical slots.
thanks,
Han
Correct Answer by gatlin007 about 6 years 10 months ago
Correct Answer by Adam Frederick about 6 years 10 months ago
Are you using a frame-relay back to back DCE/DTE cable?
You need to configure clock & intf-type as dce on frame switch.
Sounds like you may have your layer 2 info configured wrong.
Can you post relevant configs from the frame switch and router in trouble?
Adam
Overall Rating: 5 (3 ratings)
Correct Answer
Adam Frederick Wed, 09/22/2010 - 11:18
  • Bronze, 100 points or more
Adam
hanwucisco Wed, 09/22/2010 - 11:32
That's one thing that I suspect first. I configued the FR switch side as DCE for all the links. other routers all work but this R3 has Clock rate in that interface all the time and I can't delete.
How can I make sure it is back to back DCE/DTE cable?
thanks,
gatlin007 Wed, 09/22/2010 - 11:36
  • Silver, 250 points or more
If you are having trouble removing a configurable interface attribute try the 'default interface' command.
default interface ser0/0
Usually the back to back serial cables have DTE or DCE labeled on one end.  If they do not a show controller should reveal it.
Chris
Adam Frederick Wed, 09/22/2010 - 11:40
With the cable attached, you can issue a show controller.  It will tell if it's DTE or DCE.
R1#show controller serial 0/1/0
Interface Serial0/1/0
Hardware is PowerQUICC MPC860
DCE V.35, no clock
