Used Cisco 7200 series missing NVRAM
Sep 22nd, 2010
We purchased a 7200 series with a c7200-i/o and rj-45 fast ethernet ports. The NVRAM chip in missing. How can I get one? Does it have to have one installed?
Nagaraja Thanthry Wed, 09/22/2010 - 20:04
  • Cisco Employee,
Are you referring to NVRAM or are you referring to Flash? NVRAM is supposed to be part of the motherboard. So, if you do not have NVRAM, then I guess you need to have a different I/O module. If you do not have the Flash card, then you can buy one that is compatible (PCMCIA Card).
NT
allanknisley Thu, 09/23/2010 - 07:27
I am referring to the NVRAM that is supposed to be in the I/O card. When I connect to the console port and turn on the router I get :
System Bootstrap, Version 11.1(10) [dschwart 10], RELEASE SOFTWARE (fc1)
Copyright (c) 1994 by cisco Systems, Inc.
Warning: monitor nvram area is corrupt ... using default values
environment checksum in NVRAM failed
Warning: NVRAM size is 0
C7200 processor with 131072 Kbytes of main memory
rommon 1 >
  Configuration Summary
enabled are:
console baud: 9600
boot: the ROM Monitor
I can't get out of rommon.
