Unable "Call Forward All" in second line
Answered Question
Sep 22nd, 2010
Hi everyone
I can´t forward calls of the second line in my phone, the option are unable. Do you know why?
Correct Answer by Jaime Valencia about 6 years 7 months ago
Because you can't. The CFA only works for the primary line.
IPPhone callForwarder
This new version brings to the user the ability of defining and setting the call forwards from the IP Phone. When selecting the IP Phone callForwarder service, a menu with all available lines will appear. After selecting the line the user wishes to set the forward on, a new menu containing the forward definitions will show on screen. Only those forwarding parameters definied by the Administrator will be displayed. These parameters will show the actual forward destination. The user can then set any of these callForwards
http://www.myvoipsource.org/open-source-tools/ip-phone-callforwarder/
The other option is to use the CCMuser page.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Wed, 09/22/2010 - 14:58
  • Cisco Employee,
  • Hall of Fame,
    2011
java
chrisdaniels Thu, 08/04/2011 - 08:02
I have been researching being able to forward the second line on an IP phone, I have ran across several post where you
suggested the IP Callfowarder service. I tried the site and had actually registered for it back in 07, however it will not let me
log on. I tried to register again and never got a reply, do you know if this software is still available? It will really help in some
of my locations
Chris
