Reporting Query Mismatch in ICM and CVP call count
We have a Comprehensive call model for SelfService IVRs. I see a descrepancy in the Call count  for the reporting purpose.
AWDB       ReportingDB
On the CVP reporting DB, I am using a query
"Select count(*) from call where DNIS=xxxxxx
and callstartdate between datetime1 and datetime2
Say it gives me a result  <Count1>
If I run a similar report against ICM AWDB route_call_detail
select count(*) from Route_Call_Detail
where DialedNumberString=xxxxxx
and RoutingBeganDate between Datetime1 and Datetime2
Say it gives me a result <Count2>
I find that Count2 always larger thant Count1. Not sure why this mismatch. any pointer on this is will be greatest help for me.
cndilip123 Wed, 09/22/2010 - 20:52
ICM puts a record into Route_Call_Detail for every Route_Request.
Do you notice duplicate records here?
jimmy jain Mon, 02/17/2014 - 10:33
if you transfer the call , ICM Will write one more entry into RCD with same routercallkey and routercallkeyday.
hence you will find the second count always more, try using distinct keywork in RCD.
