Port forwarding on Pix 515E
Sep 22nd, 2010
What I am trying to accomplish is to forward port 80 and port 443 to allow a Microsoft Small Business Server to access Remote Web Workplace.
Thank you for your help
Here is my config
PIX(config)# show run
: Saved
PIX Version 6.3(1)
interface ethernet0 auto
interface ethernet1 auto
interface ethernet2 auto
nameif ethernet0 outside security0
nameif ethernet1 inside security100
nameif ethernet2 dmz security50
enable password XJX9T/MNG54uoaTm encrypted
passwd XJX9T/MNG54uoaTm encrypted
hostname PIX
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
names
access-list outside_access_in permit icmp any any echo-reply
access-list outside_access_in permit tcp any host 10.0.1.103 eq https
pager lines 24
mtu outside 1500
mtu inside 1500
mtu dmz 1500
ip address outside dhcp setroute
ip address inside 10.0.1.2 255.255.255.0
ip address dmz 172.16.2.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 192.168.100.0 255.255.255.0 0 0
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
nat (dmz) 1 0.0.0.0 0.0.0.0 0 0
access-group outside_access_in in interface outside
route dmz 192.168.42.0 255.255.255.0 192.168.1.5 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
telnet 10.0.1.0 255.255.255.0 inside
telnet 10.0.1.0 255.255.255.0 dmz
telnet timeout 3
ssh timeout 5
console timeout 0
dhcpd address 10.0.1.100-10.0.1.125 inside
dhcpd address 172.16.2.2-172.16.2.20 dmz
dhcpd dns 205.171.3.25 192.168.100.1
dhcpd wins 209.165.201.5
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd domain sbssrv.com
dhcpd enable inside
dhcpd enable dmz
terminal width 80
banner login Enter your password to log in
Cryptochecksum:3a32247b0d6dd90b125f3873d0e30902
: end
networ setup DSL Router>PIX>DMZ>Server
IP Address
DSL Router
174.21.215.27
Server 172.16.2.2 255.255.255.0
thanks again
Nagaraja Thanthry Wed, 09/22/2010 - 19:43
  • Cisco Employee,
Please try the following:
static (inside,outside) tcp interface 80 80 netmask 255.255.255.255
static (inside,outside) tcp interface 443 443 netmask 255.255.255.255
no access-list outside_access_in permit tcp any host 10.0.1.103 eq https
access-list outside_access_in permit tcp any interface outside eq https
access-list outside_access_in permit tcp any interface outside eq 80
Hope this helps.
NT
Mark Bracking Thu, 09/23/2010 - 10:32
This is the error message that I receive.
Remote Web Access to your server is blocked
Some routers may not work properly with your server. Visit the support Web site for your router manufacturer and ensure that your router has the most recent firmware.
Some internet providers (ISP) block ports 80 and 443 to prevent customers from remotely accessing services that are hosted on their networks. For more information, contact your ISP.
UPnP is not enabled on the router.
I tried the suggestions and they did not work. Does anyone of any other suggestions?
Thank you
Mark
Allen P Chen Thu, 09/23/2010 - 10:43
  • Cisco Employee,
Based on the IP address of the SBS (172.16.2.2), it resides behind the DMZ interface, correct?  The static statements need to be changed as follows:
no static (inside,outside) tcp interface 80 172.16.2.2 80 netmask 255.255.255.255
no static (inside,outside) tcp interface 443 172.16.2.2 443 netmask 255.255.255.255
static (dmz,outside) tcp interface 80 172.16.2.2 80 netmask 255.255.255.255
static (dmz,outside) tcp interface 443 172.16.2.2 443 netmask 255.255.255.255
You can leave the ACL as follows, which is correct:
Please give that a try, thanks.
Related Content
