LMS 3.2 supports and monitors switch-stacked?
Sep 22nd, 2010
I have 3 switches being stacked together and one of the slaves switch has been down but is not discovered and alert by LMS 3.2. May I know if LMS 3.2 is able to support it? If yes, why isn't the LMS 3.2 sent out alert when the slave is down?
Joe Clarke Thu, 09/23/2010 - 13:12
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
LMS supports the CISCO-STACKWISE-MIB and its traps.  If you are sending traps to the LMS server with DFM installed, DFM will show those traps in the Alerts and Activities Display.  From there, you would need an appropriate Notification Group setup so that these traps are sent as notifications (e.g. email notifications).
