CNF file creation error with CME 8.0
Sep 22nd, 2010
Gettign the following error messages when I am trying to create cnf files
ME-ROUTER-A(config-telephony)#create cn
CME-ROUTER-A(config-telephony)#create cnf-files
Creating CNF files
Sep 23 03:43:43.131: Can't open file XMLDefault7962-7916-24-1.cnf.xml for write
Sep 23 03:43:43.487: Can't open file XMLDefault7962-7914-2.cnf.xml for write
Sep 23 03:43:43.843: Can't open file XMLDefault7962-7915-12-2.cnf.xml for write
Sep 23 03:43:44.199: Can't open file XMLDefault7962-7915-24-2.cnf.xml for write
Sep 23 03:43:44.555: Can't open file XMLDefault7962-7916-12-2.cnf.xml for write
Sep 23 03:43:44.911: Can't open file XMLDefault7962-7916-24-2.cnf.xml for write
Sep 23 03:43:45.267: Can't open file XMLDefault7965.cnf.xml for write
Any fix for this?
Aaron Harrison Thu, 09/23/2010 - 00:40
Do you have a command like 'cnf-files location' under your telephony-service config? Sounds like it may be set to somewhere non-writable... or perhaps that location is full?
Please rate helpful posts..
MD ARMAN HOSSAIN Thu, 09/23/2010 - 15:54
Yeah I have a command cnf-file location which I set to cnf-file location tftp. But even though I did not set that command the router should use the default location which is system/ins. Bu tin my case it is giving error message without cnf file location command. Any reason why I have to use this command and what is his purpose as it has options flash or tftp?
Arman Hossain
Aaron Harrison Fri, 09/24/2010 - 00:20
Sounds like the cnf-files location is misconfigured. Try pointing it at flash:
Then do a create cnf-files
Steven Holl Fri, 09/24/2010 - 07:05
Or just point the CNF files to memory.  You don't need to store them any place specifically.
no cre cnf loc tftp
no cre cnf loc flash
cre cnf
If you still have issues, get the output of:
sh run
sh telephony-service all
sh flash:
dir system:/its/vrf1/
