How to look at VPN disconnects
sidcracker
I have a 2600 Router thats been used as a VPN device. There have been occasional vpn disconnects on a particular tunnel. How can I find out when this went down and other statistics pertaining to this?
Can you tell me any commands including the logging command for viewing the stats
nseshan
Could you explain a bit more about what type of tunnel do you have? Are you having remote access vpn using the Cisco VPN Client or Anyconnect Client? Or are you having a site to site vpn tunnel to another location?
Narayanan.
